What kind of oil pump do you guys recommend?
Do you recommend using an old one if it specs OK?
<span style="text-decoration: underline">Engine:</span>
.040" Over Pistons Balanced
Cut crank.
Balanced & lightened flywheel,clutch,pressure plate
Slightly hotter cam
Rebuilt, Ported & Polished head.
SU's
PECO
Cut crank.
Slightly hotter cam
SU's
PECO
