. Can anyone confirm or deny? (With expertise)
thanks!
Yes. The difference is huge.
A Spitfire oil pump will fit under a Midget oil pan, but every time you step on the brakes or take a turn (even gently) you'll have no oil pressure. Ask me how I know!
I have the angled oil pump in my 1500 midget and haven't seen issues with loosing oil pressure when turning or braking.
Ask me how I know!
The straight pickup is used on Midget. The angled pickup is used on Spits (because the oil pan is a completely different shape). Years ago, I got things mixed up and accidently put an angled-pickup pump into my 1500 Midget street car. Oil pressure would drop to zero when using brakes or certain turns (I forget which way). I put the correct, straight pickup version in the car and problem was solved.
