Last week I enquired about whether I should replace my oil pump with the engine rebuild. Most responders said to definitely replace - a few said inspect and if OK reinstall. While I think I will accept the advise to replace, I am curious so I took mine out tonight.
I have a gear pump, not the earlier rotary. The bush on the top does have some scoring, not deep but evident. Is that the primary concern?
The tolerances around the gears seem pretty tight (less than .002). Do I just check the gap between the gear teeth and the wall?
Most everyone claims that the rotary pump is better. Should I order a rotary type even though it was not original to my car? I assume the fit is interchangeable.
Finally, How are the two pipes (valve drain pipe and I don't know what the other one is called) removed? Do they unscrew? If so, with what - vice grips?
Thanks as always!!
Lin
1960 BT7 in restoration
1959 Bugeye
Thanks as always!!
Lin
1959 Bugeye
