Rut
What size is the oil pressure union on a 1275? The PO put a smaller line of the plastic type to go with the plastic gauge (SunPro) in the block and I would like to find out if my original gauge works. The temp side works fine and I do use the cheap gauge to verify temp and would like to do the same with oil pressure. If I know the thread size in the block, the thread size of the original pressure gauge nut, and the thread size of the SunPro gauge nut, I should be golden, no?
Thanks, Rut
Thanks, Rut
