Oil pressure union
Rut
What size is the oil pressure union on a 1275? The PO put a smaller line of the plastic type to go with the plastic gauge (SunPro) in the block and I would like to find out if my original gauge works. The temp side works fine and I do use the cheap gauge to verify temp and would like to do the same with oil pressure. If I know the thread size in the block, the thread size of the original pressure gauge nut, and the thread size of the SunPro gauge nut, I should be golden, no?
Thanks, Rut
I bet someone has done this before, placed a T in the block and run 2 oil pressure gauges. Any ideas about the thread size of the block and the original oil pressure gauge nut?
Thanks, Rut
Pretty sure the block is 1/8" BSP. A 1/8" NPT will fit pretty well. I like to use "Form-a-Gasket" #1 on the threads to help seal. Just a little wipe of sealant, not very much at all. #1 hardens. I use it on most of the fluid fittings that infrequently get removed. BSP is British Straight Pipe, which seals with a copper crush washer under the head of the stock oil adapter fitting.
What you will likely have to do is to cobble up something from some 1/8" NPT stuff from the hardware store and figure out how to mate the 1/8" BSP adapter onto the "T" contraption. That's the hard part. You might have to epoxy or solder the stock fitting into the "T". If you want a replacement stock fitting, I can supply as many as you want. I don't use them on the race engines and have plenty in parts buckets and coffee cans.
Mike
McMaster-Carr (mcmaster.com) has some BSPP and BSPT fittings. Search on their site for p/n 4860K151 and you will see a 1/8" BSPP male to 1/8" NPT female fitting. From this you can use a 1/8' NPT to 1/8" tube union and use 1/8" copper to go to the gauge. Put a 1/8" tube T in the line if you want. I would lose the plastic tubing and go with copper all the way. I learned this the hard way.
Marv J
Why not? looks good from here.
While the hole in the block is almost certainly 1/8BSP, I have never had any problem using 1/8NPT fittings. Like others above, I have used Teflon tape on some threads, form-a-gasket on others (depending on which was at hand).
Most local auto stores will carry the 1/8" copper tube oil line kits. They will work fine if you loop the tubing to form a "spring" between the block and the firewall to absorb some of the vibrations and movement from the engine rocking. Those kits will be 1/8NPT and will include a female threaded fitting that can be attached to the back of the Smiths gauge with a bit of Teflon tape.
You can also order oil gauge lines from Summit that are made from AN4 braided hose (Longacre brand).
I guess my only concern is connecting the original gauge nut to the npt fitting. The way it seals may require a washer of some type?
Thanks, Rut
Come on Rut, try Ace for washers and such.
When I clicked on the link it gave me all of the brass fittings...number 4860k441 is the one in question. Sorry about that!
Thanks, Rut
Thanks, Rut
Yes, the original Smiths fitting uses a fiber washer crushed between the back of the gauge and the nut on the line. However, as I mentioned in my last post, you can wrap some Teflon tape on the post on the back of the gauge and run the 1/8NPT fitting up on it. It will seal fine. I have done this on several gauge installations where the Smiths hose and hose end fitting were not available.
Ahh yes, shade tree mechanics at its finest. lol
Shade tree indeed! I found a local machine shop/parts store and the owner has a B and an A in parts and understood exactly what I was trying to do. Bought a 1/8" npt Tee, male x female x female ans a 1/8" nipple and it all went together in 5 min. Only had to tighten one time to stop a leak and now both gauges work and read the same.
Thanks all, Rut
Well done.
Hay nothing wrong with shade tree. That fits me to a T and I get er done.
