John Kuzman
Finally, a decent weather day to take the BJ7 out of winter hibernation. Among other projects, did an oil/filter change over winter. Have the spin-on adapter. Used a NAPA Gold filter for the first time. (used a M*** supplied filter previously). Started engine, oil pressure reads 60+ at about 900 RPM, goes to nearly 80 under acceleration. When up to running temp., reads about 40 at idle, 60 under load. Prior to this oil change, readings were just about book spec. of 50 cold idle, 25-30 running temp idle. Oil is the same as always, 20-W50. Could the NAPA filter affect the system pressure? Anti-flowback in filter causing pressure increase? Are these readings I am seeing a reason to be concerned? Thanks.
