Guy Marshall
Awhile back I bought an oil cooler sandwich plate with thermostat. I finally got around to fitting it and discover the oil pressure now takes 3-4 seconds to get to 60 psi. This is a lot longer than before as it used to get to pressure immediately.
I removed the filter and sandwich plate and I can see the filter (Wix 7074) has an anti-drainback valve and is full of oil. The lines and the cooler are both lower than the filter so they were full too. I replaced the oil filter without the sandwich plate, waited 24 hours before restarting the car, and the pressure came up immediately.
Has anyone else any experience with thermo sandwich plates causing this issue?
