Recently, I was couple blocks from home when suddenly the oil pressure went up to around 100 PSI. That is not normal for my car as it should be 60 PSI at speed. I quickly returned home and fixed it by repairing the Oil Pressure Relief Valve's little plunger (thimble shaped item).
I have two questions: 1) if that oil pressure valve is completely blocked will there be no oil being distributed to the engine's rocker/camshaft area or to the mains? and 2) does the oil passing through the oil pressure valve go directly from the oil pump or does the oil first pass through the oil filter?
FYI my car is a 67 BJ8.
Hi Guest!
