I am having a problem with oil pressure on start up. Instead of registering 60lbs +/- when cold my pressure is only 38-40 lbs at idle or even when the engine is revved to 3000 RPMs. After the car warms up to operating temp the oil pressure slowly rises and then settles at the normal 50lbs at 3000 RPM and 35-40 at idle. Can anyone offer an explanation or solution. Only mods to my BJ7 is an oil cooler and spin-on filter. I guess I shouldn't be too concerned but odd that on startup pressure is so low. Before I installed the spin-on filter and oil cooler pressure was 65-70 lbs at start up.
Thanks,
Thanks,
Hi Guest!
