Well I was thinking I took good notes on this before I took it apart but I need to make sure. Question is with the stud used to hold the oil line banjo fitting to the filter head. The stud I have is 2 1/8". Should there be any groove in the stud or does the oil just pass thru the gap between the head and the stud? Also does the brass washer with the larger hole go on the inside, and smaller on the outside of the banjo? This setup sure looks like a leak waiting to happen.
