Oil pressure gauge has been "stuck" at 55psi since arrival a week ago. Engine on, engine off, engine fast, engine idles, gauge always shows 55psi.
So with a *lot* of patient advice from guys here I loosened the line nut and slowly pulled the line away from the gauge.
Voila! The needle dropped to zero. So I know the gauge isn't frozen.
Reconnected the line, started the engine from cold, and the needle slowly moved from zero up to around 45. Engine warmed up, throttle open to around 3000rpm, needle moves up to 55. Back to idle, needle drops to around 45. Are these pressures anywhere near what's to be expected? Way low? Way high?
I cut the ignition, the engine stopped, and ... needle stayed at 45.
I'm thinking the oil line is plugged - make any sense?
If so, I'll open both ends of the line tomorrow and try to blast some air through.
And for the heck of it today, I also did a compression reading on all four cylinders. 120 120 122 120. Throttle not open, engine not fully warm, only one plug out at a time. I don't have a clue what the readings "should" be, but they're almost identical - and that's good.
And the starter button at the firewall sure makes life easier.
Tom
Tom
