TR2/3/3A Oil Pressure Gauge Leak - Leather Washer?
PatGalvin
Hi guys
I am having a leak behind my oil pressure gauge. I see Moss has shows a leather washer between the oil pressure line and the gauge. Is anyone familiar with this? I'm sure I did not install a washer in this location (I know, seems obvious now). I'd just like to hear from the informed collective.
Thanks - Ran my new engine for a half hour and got it hot enough to cycle the Spal electric fan a few times. Worked beautifully. I was surprised to seen the idle drop down a bit when the fan load kicked in and the Bosch alternator had to work a bit.
Pat
TR3driver
Great Pumpkin - R.I.P
Definitely needs to be a washer of some sort there, or it will leak. I'm pretty sure I used nylon last time, didn't know of a source for the leather and grabbing a nylon washer was easier than trying to make one from an old belt.
mgedit
Likely not too hard to make from leather. I believe I bought one from TRF when I was placing an order. Might an o-ring (nitrile) work as well? Cheers, Mike
6TTR3A
O ring will work; nylon washer (#6) better; the original leather type is OK but if you make your own, be sure it's thin enough.
Frank
martx-5
I used the original 45 year leather washer. No leaks....knock-on-wood
Vila
The TR4 uses the same leather washer. When I put my gauges back in I used the original also, but on my next Moss order for other parts I bought a spare. Can't beat the price of $0.45
Visit my new and improved personal website at: www.jakegingervila.wix.com/bobs-vintage-cars-
Vila
1933 Chevrolet
1962 Triumph TR4
1984 BMW 633 CSi
PatGalvin
PatGalvin
This is good info guys.
Thanks
Looks like many of you use the leather washer. For less than 4 bits, I'll let Moss send me one!.
Much appreciated.
Pat
CJD
Like you, Pat, I didn't know a washer was supposed to be there. I tightened it down and it quit leaking. I've been meaning to go back and add it...for the last 3 years.
TR3driver
Was it actually leather?
TR3driver
Might, but I've had problems trying to use O-rings in similar situations. The problem seems to be that O-rings are soft and will stretch/deform under pressure unless they are constrained in all directions. They need to be installed into a groove to seal against pressure.
PatGalvin
PatGalvin
Just a final follow up to this thread. I am running a SS flex hose to my oil pressure gauge (purchased from Ted at TSI). The flex hose has an adapter to attach the flex hose fitting to the gauge. I purchased a $0.45 leather gasket from Moss and installed it between the adapter and the gauge. and Voila, no more oil leak behind the gauge.
So yes, I think that the leather gasket does the trick!
pat
Bareed
Members, I recently purchased a 76 TR6 and have noticed that there is oil behind the glass on the oil pressure gauge. I have removed the gauge, and have disassembled the unit to see if there were any obvious leaks. The leather washer was in place. There was nothing visible to the eye. The car has not been started in 5 years. How would I test to see if the oil in the gauge was from a loose fitting/connection, or from the actual pressure mechanism? Also any suggestions on what product to us to clean the gauge face and interior. I do not want to damage either. Thanks for the assistance.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
