twas_brillig
Moved the BJ7 Healey out of 'winter' storage in early June; brakes real iffy (fluid leakage?) and the engine puked oil the whole 'move around from behind garage to driveway'. Dang, as the only problem last fall was that the o/d had quit.
Turns out that oil was gushing out of the upper end area of the braided line from the block to the fitting taking the oil pressure up to the oil pressure gauge.
I've pulled the line and there was nothing obviously wrong with it nor the connection (that I could see). I've ordered a replacement braided steel line, but: is this a common problem? any advice on the wrench sizes that work (Imperial worked on the engine end; 13 mm was just a hair too tight on the upper end).
Wisdom solicited!
Doug
Wisdom solicited!
Doug
