Guys, pay attention to what Tom Bedenbaugh says...he's the expert!
...however, if an engine of mine is making strange noises from the bottom end, I pull it! 2 hours to get it out is child's play...&, if its making noises, its too late to just refresh the bearings....
...disassemble, take to good machine shop...bore, balance reciprocating parts, blueprint, have them check everything...when you get it back, all new parts torqued down just like it was the last time with plastiquage...then disassemble, clean & put back together for final time...plastiguage is cheap & easy to use &, though not 100%, gives one a good feel for how everything goes together!
But, every man has to build his engine the way he sees it!
