TR2/3/3A oil pan bolts
MKN
looking to work on my TR3A oil pan. There are 19 bolts. Moss looks to 17/18 of one type, and 2/1 of another. Any idea which 2 (or 1?) are different and why different?
Joel Lester
The different bolt length(s) is to mount your breather down tube in it's location. Pretty sure it only fits one way...
Joel
Hamish Racing
All I can say for sure is this is the pattern I took off mine before fitting the aluminium sump.
One long where the rod that is the slave cylinder stay is attached to the sump bolt.
I cannot guarantee it’s original.
bobhustead
Harnish said it better. Picture worth 1000. The same bolt does also appear to be used on the breather, per the moss site, but I don't think it goes thru the oil pan flange.
M
MKN
thank you Hamish
Sarastro
It's really not that critical. Most are through holes, so lenght is not critical For the rest, you can use anything that fits.
Hamish Racing
You don’t want too long bolts in the end bridge block as they are only Ali and will pull the thread if too long and you try and pull the pan up tight. At the side it doesn’t matter as they are through holes.
Also f you try the thicker cork gasket forget the torque setting 14-16ftlb I think??as it will distort the gasket a lot.
just comfortably tight to seal is enough
bobhustead
To follow on Harnish's slight expansion of the topic, prepare your pan for installation with moderate ball-peen hammer blows to each hole on the flange, from the top of the pan, so as to remove any upward distortion of the holes caused in previous installations. And rest the pan flange on a block of wood as you hammer.
sp53
Hey Hammish I was looking at your picture and did you shorten the breather pipe for racing. If so, does the shorter pipe have any effects on anything?
steve
Hamish Racing
steve
Steve
The PO did it
Cut at the top of the up direction so no return direction to the road.
It’s connected to a vent tank that also takes valve cover vapour.
The new engine has the block vent sealed and the breather comes off where the fuel pump was.
RJS
Totally agree with Hamish on torque setting on cork gasket. Ask me how I know &%#!
sp53
Sorry for liberating the thread, so Hammish then your car does not drip oil at all because you catch the drips in a container?
1 Austin oil pan bolts. Austin Healey 4
KVH TR4/4A TR4/TR4A Oil Pan Bolts Triumph 4
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
S 1275 oil pan removal Spridgets 30
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
I Bugeye oil pan help Spridgets 3
T Oil pan leak? Spridgets 7
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
D Oil Leak at rear of oil pan Spridgets 11
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
T TR6 Oil pan Triumph 5
R GT6 Oil pan bridge installation Triumph 15
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
K TR2/3/3A Oil pan Again.... Triumph 4
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
bugedd Front suspension and oil pan Spridgets 17
bigbadbluetr6 TR6 Oil pan gasket Triumph 2
Michael Oritt Leaking oil pan Racing 8
RJS General TR Straightening Oil Pan Triumph 5
D TR6 Tr6 oil pan Triumph 3
J Measurement for aluminum oil pan Austin Healey 3
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T six cylinder oil pan - wtb Austin Healey 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
SMGoose Oil pan Triumph 9
Crankshaft Oil pan gasket seal Triumph 10
DNK Oil pan Gasket Triumph 7
T TR6 Will a 71 TR6 oil pan come off in the car? Triumph 3
R Alloy Oil Pan from Moss Austin Healey 9
M Leaky oil pan... again Triumph 16
I source for used 948 oil pan Spridgets 4
Morris Oil pan gasket Spridgets 10
M Oil pan torque Triumph 23
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
T 1500 oil pan is off, what should I look for? Spridgets 20
S oil pan bolt Other Cars 9
hondo402000 Oil pan heater Triumph 11
Superwrench Oil Pan -black Austin Healey 3
M TR2/3/3A TR3 aluminum oil pan Triumph 9
4 '03 X-Type 2.5L Oil Pan Gasket R+R ? Jaguar 2
N BJ8 Dented oil pan Austin Healey 28
mountainman TR2/3/3A TR3 Oil Pan Gasket? Triumph 7
A TR2/3/3A Triumph TR-3, 4, and 6 alum. oil pan Triumph 3
H Aluminium oil pan Austin Healey 9
W oil pan bolt questions Austin Healey 18
mountainman TR2/3/3A TR3 Leaking oil pan Triumph 17
GBRandy Oil Pan Gasket Installation Triumph 11
livinginthepast Beautifying the oil pan-948 rebld. It's the pits! Spridgets 12
