There should be vacuum on the port on the PCV valve. When I hooked the vacuum gauge to that port the vacuum was zero for a second or two and then it went to about 10 in-hg.
I was thinking that maybe the valve cover, when sealed, would allow the vacuum from the PCV valve to remove the pressure from the crankcase. It seems to me that there should be some restriction to allow the vacuum to increase.
I apologize if I am not being clear. I guess I just don't artikulte vury good.
Thanks, Pete
Thanks, Pete
