Subj. 1979 MG Midget 1500 engine..
I have a bad oil leak coming from the front of my engine. I even pulled the engine to check where else it might be coming from. I found NO other place except from the front of the oil pan. (Front main seal and timing cover gasket have been changed) I have changed the pan gasket 4 times and used plenty of RTV Blue silicone on both sides of gasket. I pulled that gawd awful aluminum cross bar, cleaned it up and the front of the block where it sits used plenty of RTV blue and new gaskets (including the wooden ones) assembled every thing back. Put the engine back in the car and low and behold instant leak from the same place. I took the oil cap off the rocker cover, started the engine put my hand above the oil filler hole and could feel air puffing out and it really leaked oil out fast. A steady run in seconds. Put the cap back on and it slowed to a steady drip drip drip.Anybody have any ideas ? I've about given up. This has been a problen since I bought the car 2 yrs ago. Could I have a bad oil pan. It looks ok to me. Any help would be appreciated.
Thanks Don
Thanks Don
