A few weeks ago finally got to the point in which i could start my Midget for the first time. Now that its running the next list of problems are starting to arise, as expected. Now with the electronic ignition installed, im sure my timing is not exact but close. The engine is idling at about 2k to 2.5k. After a bit it will lower to 1.5, any lower and it begins to misfire to often and die. I think the problem may be the combination of the carbs needing adjusting, the oil that im burning from some place and the timing being off. Otherwise its not over heating and it seems to be running strong. Any suggestions on what i should work on next or look into. Also what should my oil pressure be sitting at. Currently its hovering around 70-80 with the high rpm.
