nicko
Hi guys,
just a quick question,
My gearbox started to make a low whining sound which stopped when I put my hand on top of the gear stick.
I believe from reading the forum that it's common in first gear but it is also in the other three gears.
The first thing I did was to check the oil in the gearbox which is a bit low so I've decided to change the oil.
The question is what type of oil do you recommend and how much oil do you put in?
I've read somewhere that not all the oil drains out so you can't put it all in. In the manual it says 7.5 U.S. pints /3.6 litres.
This is with an overdrive fitted , is this correct ?
Thanks for all the help from last time with the manifold problem. I got that one sorted.
Cheers,
Nico.
Cheers,
Nico.
