AUSMHLY
BJ8. I may have a leaking head gasket?
Today, engine cold, I removed the radiator cap, I see green antifreeze. I don't see the top of the radiator fins. I did when I changed the antifreeze 150 miles ago. Should I be able to see them? If not, does that mean I have oil in the antifreeze?
After a half-hour drive I see a lot of condensation under the radiator cap and valve cover. Not sure if it's water or antifreeze. Hard to tell by taste test. I've been told the engine isn't getting hot enough to burn off the condensation, but now I'm wondering if it is antifreeze being I can't see the fins in the radiator. Related?
Leaking head gasket allowing oil in antifreeze, antifreeze in oil?
Oil dip stick shows clean oil. Oil seems OK under rocker shaft. Not milky or thick.
What can I do to confirm if I have a leaking head gasket?
