Joel Lester
I installed my new cam bearings into my engine block last night after getting back from the machine shop.
I was able to line up the set screw holes perfectly - not on the first try of course! But, after a few tries I got it perfect. On the flip side however the oil holes that feed the camshaft bearing are not exact. The hole is patent for sure and believe me they are not significantly obstructed but that hole is not very big to begin with.
I made sure that the correct bearing went in the correct spot and that the orientation of the bearing was like it is supposed to be. I did a lot of reading and watched a number of videos on this topic before I attempted the procedure. I also read that the oil holes are intentionally small so that more oil will be passed on to where it is needed more - like the crank main bearings and on up to the rocker etc. and the camshaft doesn't need very much oil because the load is not that much.
Just looking for a little reassurance that this will be OK??
Thanks in advance for your input!
Joel
Joel
Hi Guest!
