TR2/3/3A Oil gun for 'Propeller shaft" lube
RC64
I seem to recall some discussion in the past about the grease gun versus oil gun requirements. The search function didn't cooperate when searching for 'oil gun'. So let me raise the issue again with regard to the guidelines in the manual.
The manual says to use an 'oil gun' to lube the three points on the propeller shaft (R). I've never seen an oil gun that fits a zerk (my experience in the automotive realm is admittedly very limited).
Any suggestions as to how I might properly lube these points with oil? And what type and weight should I use?
If anyone has them, a pointer to those earlier threads on the lube process in general would be most helpful.
Rick...
Geo Hahn
Seems to be some debate. The STC manual (you cite) says 'oil'. The TR3A Practical Hints (owners manual) say 'oil' for the U-joint and 'grease' for the splines. The Haynes manual says 'grease' for all 3.
I have always used the grease gun on all of them. I have to believe that modern grease is superior to anything that was available 60 years ago.
R
RC64
Do you use the same type grease that is used on the rear axle hubs? I just got done replacing an improperly installed inner seal on the right axle so my grease gun is nearly full.
Since I'm 75 and not likely to get another 100,000 miles on the car it's probably not going to matter if I use oil or grease... for me anyway. :smile-new:
TR3driver
Great Pumpkin - R.I.P
Ditto on using grease in all 3 driveshaft/propshaft zerks, in spite of what the books say. FWIW the 4A owner's manual says grease for all 3.
However, if you do want to use oil, there is a Mercury Marine grease gun that is designed to take grease in plastic "toothpaste" tubes. Mercury Marine also sells GL4 gear oil (in a special formulation that is specifically safe for copper) in a "toothpaste tube" that will mate with the grease gun. Not perfect, but it will pump oil through a zerk as long as you hold the gun upside down. Then you have to store it the other way (with the tube hanging down) or it will leak.
PS, in case anyone else is wondering about "Practical Hints", it is basically the owner's manual for the TR3/A. You can download a copy of the 6th edition (suitable for late TR3A) from https://drive.google.com/open?id=0B2H2NJt34OffNjQ4MTkyNjItZTVmYi00M2U2LWJhYWUtMjEyZDgxMzUyNzUw
SASSAMON
Here is the Mercury Marine Grease gun that I use for putting oil into the zerks when the owners manual calls out for oil. 91- 37299A 2 Grease Gun
As mentioned, an 8oz tube of oil will screw right onto the gun.
Roger
bobhustead
I would not likely run any joint on liquid lube unless the design incorporates a bath of the lube. E.g. older 4wd steering knuckles that held a sealed chamber of lubricant around a ball bearing u-joint or unsealed cross and roller joint. Liquid by itself will not stay in place (gravity, centrifugal force).
R
RC64
Good points, all.
I'm not inclined to argue with success while making the job more complicated. I'll go with the grease.
2liter4cyl
Bronze
FYI: to make it easy to grease a u-joint, get an adapter for the gun. ( It acts like the needle for a basketball,) then it will fit the little ball on the zerk. Not unlike some oil cans.
It works in tight places where there is no room for the grease gun end. Can be found at most lube outlets. Le T.
Brinkerhoff
It is pretty gutsy for the British to think they can contain oil inside of a u joint , given their success with engines, gearboxes , rear axles ...
M Oil Gun vs Grease Gun Spridgets 21
B TR6 Oil in a grease gun for TR6 lower steering swivel? Triumph 16
71tr How to pump oil through a lube gun? Triumph 4
jlaird Oil gun Spridgets 0
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
