Oil gallery plug
Gerard
I was just about to fire up a 1275 I've completely rebuilt and while cranking to get oil pressure, discovered that the front oil gallery plug is leaking profusely. The machine shop installed new ones. I had a feeling I should have just left the old ones, but you can't really get the block clean without pulling them. This has never happened to me before. Anyway, I have this thing all set up on a test stand and don't want to completely disassemble things and haul it back to the shop, so I'm wondering, since it's accessible without taking anything apart, if there is anything that be done to stake this one better. If not, my other thought is to yank it out and thread the hole for a pipe plug. I can't locate the two I pulled out of another block I have, so I'm wondering if anyone can give me the correct size I need to do this.
bug_sixty
Well, here's what I found on mine....the U and L gasket set with the black head gasket didn't include that copper O ring....I had to buy it from a place that sells such... They didn't the the water ring either....Who knows what improvising was done in your assembly. sorry don't know the size
Gerard
Gerard
I met the collapsible copper ring....one and only that does the trick 80lb of pressure....
Are you referring to the head gasket? I'm talking about the oil gallery plug at the front of the block, just below the water pump. (see 2nd pic)
The originals are a thick brass plug, but what you get today is a metal cap, similar to the water jacket freeze plugs.
I do not know the size, but wouldn't tapping it create a risk of metal swarf in the oil.
Gerard
Gerard
Yeah, there's that, but with some grease on the tap and the fact the the hole is horizontal, it would be pretty easy to clean out with a magnet and a couple Q-tips. I'm tempted to see if I can knock this in a little farther and see if I can stake the edges first. I'm just not sure if that's a secure solution. Another option is to remove this one and see if I can find some brass bar stock that would be a press fit.
Gerard
Gerard
Also, someone out there has the real deal plug in there spare bolt jar.... I would wait and getter right....
If someone does or have a source for one, I'd like to know.
Gerard
Gerard
So you are using a straight coarse thread rather than a pipe thread. I have one race engine done this way, but I will probably do threaded plugs in all future builds.
Dug
Gerard, you have a PM....
I put 1/4 NPT pipe pipe plugs in every MG engine I build instead of the brass plugs, but i don't think I would do this now in a built engine, the oil galley is no palce you want to have any metal shaving in, it's a direct feed to the crank bearings. I would repalce the plug, or use a steel type core plug.
Alan, I think you meant 1/4" NPT.
TRclassic3 TR6 TR6 Leaking oil gallery plug Triumph 5
B TR2/3/3A TR3A Oil Gallery plug Triumph 6
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
R General Tech Aluminum oil gallery plugs Triumph 3
J 100/4 oil gallery problems Austin Healey 0
A TR6 TR6 Aluminum oil gallery plugs Triumph 4
TomMull TR2/3/3A TR3 oil gallery plugs Triumph 2
6 Oil Gallery Plugs what size Tap? Spridgets 10
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
