Oil for Steering Rack?
ABfish
While trying to get my Sprite up to par with a general service and lubrication, I put a couple of pumps of grease into the steering rack. As I looked at the manual later, I see that it calls for oil in the steering rack.
Does anyone add oil instead of grease to the rack? How do you get oil in through a standard zerk fitting?
I gotta say that I haven't noticed any adverse effects from the errant grease injection.
I'd check under the boots, If they are dry then you know the grease has gunked up. I use a very thin grease and it makes its way out into the area where the inner tie rod end is located.
V
vagt6
I installed a new OEM rack in my MK III Midget, it has no zerks, nowhere to oil it.
Anyone have experience with one of these? Where does the oil/grease go in? :wall:
A
ABfish
I've never seen a "thin" grease for use in a grease gun. I've always used high pressure grease that is recommended for chassis lube, u-joints, etc.
nomad
Trevor, I believe, use's John Deere corn head grease. That may be a little hard to find for some of you. I use 80/90 thru an old gun with the grease tube plunger taken out. I just make sure I keep it verticle and it pumps 80/90 just fine.
Kurt.
A
ABfish
Kurt.
Thanks, Kurt. That's a good tip. I've got an old gun that I'll convert this weekend.
jlaird
The orginal oil gun had a on the end that you just pushed, it was spring loaded and was used vertical.
PAUL161 Steering Rack Oil MG 6
TulsaFred Steering rack oil Spridgets 4
W steering rack oil MG 11
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
RickPA Need help installing steering idler oil seal Austin Healey 6
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
R Steering box oil Austin Healey 39
B TR6 Oil in a grease gun for TR6 lower steering swivel? Triumph 16
R Steering Box Oil Triumph 6
N BJ8 steering box leaking oil Austin Healey 11
T steering box oil seal Austin Healey 4
af3683 TR2/3/3A Proper Oil for TR-3 Steering Box Triumph 22
S Steering box oil seal replacement Austin Healey 3
bighealeysource Steering box oil - type ? Austin Healey 3
AUSMHLY Steering box oil Austin Healey 11
A Steering box oil seal question Austin Healey 3
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
Dave Richards Steering Oil Austin Healey 12
Westfield_XI Steering pinion oil seal Spridgets 11
A The Groaning Steering Column - Where to Oil? Austin Healey 1
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
