TR6 Oil Dipstick Tube
jhedge
Hello
Does anyone know of a place where I can purchase or source an oil dipstick tube for a 73 Tr6. Item did not come back from engine rebuild shop and they are n/a from major parts houses
Car has been put back together but I have not proceeded since Dec due to military service. Had lead on this forum from member but never followed due job service requirements. So I am again asking if anyone can help out.
Thanks for any help
jhedge
glemon
I have one, It seems to be quite stuck in the block, are they supposed to just be a friction fit or screw in and out? I tried a strap wrench, but it wouldn't really grip on something so small. Don't think a vice grips would be a good idea, anybody have any ideas how to best get it out?
Happy to send it your way once removed, Greg
Vila
lemon
I'm not sure how they are supposed to come out either, but if you have a small metal rod that fits inside the tube snuggly then you may be able to use something like vice grips without crushing the tube, but it still may put tooth marks on the outside.
I have also made tools out of small pieces of wood to grip items like this without putting vice grip tooth marks on the part. Drill a hole in a piece of wood, with a drill the same size as the tube, and then cut the wood in half with the grain and through the center of the hole. Then place the two pieces together and drill a hole through each side of the hole so you can bolt the two pieces together with the holes halves aligned. Place the wood tool around the tube and bolt together then you may be able to remove the tube by either twisting and/or pulling. You may still what to put a piece of metal rod inside the hole so you don't crush the tube.
J
jhedge
From my understanding they are just friction fit. If you are able to retrieve I would be happy to cover all costs to ship. Let me know if you are successful and I can make contact.
Thanks for you help this part has been impossible to source.
Jhedge
TRopic6
I just checked the one in my '69 parts engine and like Greg found it to be in there pretty solid. That block has to go at some point - when I open it up I'll see if I can tap it out from the inside...unless Greg has better luck.
Jeff
glemon
I tried this morning, adjusted a small vice grips with curved jaws to just go around the tube and catch the lip on top. Tapped gently upwards......nothing. Tried a little heat, same result, however, my efforts were hampered somewhat by the wife being asleep and the bedroom being above the attached garage. Currently have some PB Blaster soaking in, will try again later, but the method holds some promise, as the tube held up well.
glemon
More heat more tapping, success, let me know where to send it. Greg 20160327_091029.jpg
J
jhedge
Greg
Thanks you are a life saver.
I sent you private message with my address information.
Joe
P No Oil on Dipstick Other Cars 1
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
pjsmetana My Oil Dipstick has 3 lines Triumph 11
tweety Dipstick oil spray/leak/ooze/whatever Spridgets 5
C Oil coming out the dipstick Triumph 7
johnrip Wedge tr7 spurting oil from dipstick Triumph 6
O Leaking Oil around dipstick British Motor Corp 5
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
