G
For those of you who have considered adding an oil cooler radiator to your TR6, the recommended location by Triumph is atop the skid plate and directly in front of the radiator. The only problem with this technique is the oil cooler is made of thin aluminum and simply bolting it into the ready-made holes will result in a very flimsy setup at best. I have actually seen one of these vibrate enough to cause the cooler to crack and extract all the contents of your sump on the roadway. Great way to burn up an engine. I found these top and bottom brackets in a set from Earl's on the web, included with rubber cushions inside. I had to enlarge the holes for the hoses a little. The good part is I bolted the whole apparatus through and through with stainless steel allthread and locked everything together with stainless nyloc nuts and washers. Trust me, the thing simply does not budge!
Bill
Bill
Hi Guest!
