Oil cooler adaptor plate problem
peteatgr
I've been trying to get my Moss 13 row oil cooler installation completed. The cooler radiator is installed fine and the hoses are run, but I'm having no luck in getting the adaptor plate to fit between the oil routing pieces from the engine block to the filter bowl. When I face the hose connections forward the hoses don't have enough room before impacting the distributor. If I face the hose connections to the rear, the hoses don't reach with out kinking (and I think in this mounting direction the oil will run first to the cooler and the cooler people say it should first go to the filter). Has anyone used the adaptor plate supplied by Moss to integrate an oil cooler? If so how did it mount up and not have the hoses conflict with the distributor body? Maybe I got the wrong adaptor plate with my cooler. The Moss folks didn't really have an answer.
I just started to revamp my oil cooler installation this week, I'll have to get the pictures off the camera and onto the web, but I didn't use the Moss stuff (I made my own).
Tomorrow (Friday) I hope to get all the hoses run, so you should be able to see what I've got in another day or so.
I don't understand why the pictures didn't turn out except as links; trying again...
Dave Richards
Nice work, as usual, Randy.
Very patient with the file, that one.
GregW
Hi Peteatgr
I bought my sandwich plate from Smitty. Don’t know if anyone sells them now. His could swivel 360 degrees, then you just tightened the filter adaptor to hold it in place.
Maybe what you need are angled hose ends. Here is a photo of my oil cooler. One hose has a 90° end to keep the hose below the radiator. The other hose has a 45. A local speed shop should have what you need, otherwise online at https://russellperformance.com/new/ or maybe https://www.bakerprecision.com/ to name a few.
P
peteatgr
Thank you Randy and Greg. While Randy's beautifully manufactured component is probably the most perfect solution, I can easily say that I'll probably not be doing that kind of quality milling. I think my first try is some angled hose fittings as per Greg to see if I can make the hoses miss the side of my distributor without having to change anything major.
Probably the most important point for others interested in oil cooling is that the Moss kit is not a perfect fit as it arrives in the box. I think my car is fully original and I don't see any way to make the adaptor plate work without confilct with the distributor as it is configured. Might be me or might be my car - don't know.
Greg, I don't know who Smitty is to whom you refer. Can pivoting adaptor plates still be obtained through this source?
GregW
Hi peteatgr,
Smitty is the man behind the Toyota 5 speed conversion for our Healeys. He recently retired and sold his business. I don’t know if the new guy (who bought the business) is selling the oil cooler adaptors or not. Actually, I don’t even know who the new guy is or if he has a web address.
Keoke
Current Distributor of the "Smitty Five Speed Conversion": Healey 5 Speed Located in ; Harrisburg, N.C. Phone #: 704-455-2585 - /ubbthreads/images/graemlins/cheers.gif-Keoke- /ubbthreads/images/graemlins/cowboy.gif
Keoke
[ QUOTE ]
randy, nice! ah my kingdom for a milling machine. /ubbthreads/images/graemlins/yesnod.gif
[/ QUOTE ]
----------You'd be too old to learn to use it!!-- /ubbthreads/images/graemlins/lol.gif
[ QUOTE ]
[/ QUOTE ]
I told my wife that I wanted a milling machine and a lathe when I grow up; she's still waiting for me to uphold my end of the bargain... /ubbthreads/images/graemlins/devilgrin.gif
Michael Oritt
[ QUOTE ]
[/ QUOTE ]
Randy--
Tell your wife that anyone can act his age. It's much more difficult to remain childlike-something that I always try to do, though some say I am simply childish.
Keoke
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Sounds like some of those other dead beat husbands I be reading about in the papers.--Keoke- /ubbthreads/images/graemlins/angel.gif
keoke, im allready too old! and those things can be dangerous least when i now count my fingers they still add up to 12. /ubbthreads/images/graemlins/grin.gif
Here's a few more pictures from yesterday. I thought I'd have it all finished by now (famous last words, I know) but the plan was to reuse the -10 adapters that were already on the remote filter housing; turns out they were -8! If I order the -10s early enough Monday, they'll be in my hand Tuesday (unless I get lucky and find some in town today).
This is the Rube Goldberg adapter that I wanted to be rid of:
Celtic 77 MGB 77 MG B oil cooler MG 5
B Oil cooler Austin Healey 21
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
MikeAH100M Interesting Oil Cooler Austin Healey 6
H oil cooler and overheating Austin Healey 12
JPSmit engine oil cooler question Spridgets 11
RAC68 Routing Oil Cooler Lines Austin Healey 16
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
DanLewis Oil cooler hose adapters? Spridgets 12
Branson oil cooler mount Spridgets 20
6 Oil Cooler Spridgets 3
R oil cooler need for 1500midget with 9:1 comp ratio Spridgets 3
H oil cooler overall cooling component Austin Healey 7
P broken oil cooler fitting MG 1
D oil cooler Spridgets 12
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
V How much extra engine oil with oil cooler??? Spridgets 5
8 TR4/4A TR4A After market Oil Cooler Triumph 5
DerekJ Is my oil cooler a waste of time? Austin Healey 1
S Oil cooler and spin on filter adapter Triumph 10
tri_carb_healey oil cooler question. Austin Healey 5
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
B TR6 TR6 Oil Cooler hoses Triumph 1
rikiwho123 oil cooler kit Triumph 0
D Help! Blew an oil cooler hose. MG 17
HealeyPassion AH oil cooler ducts Austin Healey 16
A Oil Cooler Washer MG 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
Sebring222 MGB MGB Oil Cooler Thermostat MG 4
Tabcon Oil Cooler Install Help Racing 0
angelfj1 Oil Cooler Leak Triumph 8
jaegzie Do/Should I use an oil cooler. Spridgets 11
losmorob Looking for an oil cooler kit Spridgets 7
chrpark oil cooler install and fitting pictures Spridgets 1
0 1500 oil cooler Spridgets 3
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
tony barnhill '63 Midget Oil Cooler Hoses Spridgets 5
angelfj1 Oil Cooler Leak Triumph 9
J Oil flow direction and oil cooler Spridgets 14
Jim_Gruber Oil Cooler Hoses / Rerouting / Hole Saw Spridgets 5
Baz Oil Cooler lines... Spridgets 0
G Oil Cooler question Triumph 14
beez Oil Cooler with Thermostat Installation Question Triumph 8
B 1500 Oil Cooler Spridgets 7
Jim_Gruber Oil Cooler Hoses - Routing and supporting Spridgets 10
D Oil cooler MG 6
WALTER Benefit of an oil cooler Austin Healey 7
