Oil Capacity 3000
AJAX50
I found that with the oil level at the correct level on the dip stick that under (very) heavy breaking the oil pressure went. I have fitted a baffled sump which has cured this problem. However I also understand there is an increased volume of oil around the rockers at highish revs so I have decided to keep the oil level about 3/8 inch above the correct level. I can't see any down side to this.
Dave Richards
I checked the dimensions of the stick and tube:
4-1/2 inches for the tube and 17-3/8 (not 3/16")inches for the stick.
After about 25 miles of driving, the oil reads about 1/4 inch below the max mark, that's where I'm going to fill it to from now on.
Thanks everybody for your input and help.
gra
Member
Does anyone no the length of the dip stick for the early BJ8? Was it longer or shorter than the 17 3/16s or 17 3/8s discussed in this thread.
Just purchased an early BJ8 and dipstick shows over full with 5 quarts. Engine number plate missing and have concern with amount of oil in car. Thanks
Johnny
Dave, you might have the wrong dipstick as Keoke mentions, or maybe you have too large a washer mounted on it.
Editor_Reid
Platinum
Sid,
No Austin-Healey ever came with a diesel engine, so it's doubtful that anyone in this forum would know the answer to your questions (of course, knowing this forum, my comment will likely motivate someone to go find the information and post it).
I don't know if there is a forum for the engine you're inquiring about, but there likely is. A web search is your best bet.
Good luck.
Michael Oritt
Perhaps some are calculating after pre-filling the oil filter, or measuring after the engine haas been run and approximateley a quart has been pushed out of the dump and into the filter....
Goldie
A little off this topic but related. I have started seeing Castrol 20/50 Classic Oil at Walmart. Has ZDDP. Only see it in quarts so far. I have been adding ZDDP with oil changes. Anyone seen the Classic version in 5 quart container?
Also the Fram filters don't have a good pressure spring and for most of us who don't change the oil but once a year due to limited driving, the K&N is much better made. WIX also makes a good filter, but I don't know the number.
Because it's eBay, and they sell stuff in all 'conditions?' If you go to the page, it's not in quotes.
I bought a case years ago, and I sleep very soundly knowing I'll probably never have to buy another oil filter for my Healeys ;) These fit the spin-on adapter that Moss has been selling for years, with a Fram PH3600; they might not fit another type. For about $5/ea, you can't beat this deal. As for oil, Walmart sometimes put Valvoline 20W-50 Racing Oil for less than $5/qt.
I bought these a few years ago; to the best of my memory from this seller. They were new and shrink wrapped and the box was sealed. If you’re losing sleep over this, don’t buy them. Problem solved.
RDKeysor
Bronze
As it happens, I changed my '60 BN7's oil a week ago after a 175-mile outing in 90 degree temperatures. I went to the standard booklet that most of us carry in the car and didn't find a stated engine capacitiy. My sense is that good manuals should provide capacity information. So, I drained the sump thoroughly. I then very gingerly (meaning I kept checking the sump level) added six quarts of oil that brought it to the level I thought prudent. The new filter was given a shot of additional oil before installation, the engine turned over for a few seconds with the coil disconnected to insure the filter filled. I then took the car for a short drive and can report that the oil level is just barely below the max mark. Since a forum contributor did this earlier, I measured from the bottom of the red ring that serves to stop the dip stick's insertion to the tip of the dip stick (forgot to measure to the marks) and found that to be 12 1/8". I must add that this car has the Moss aluminum sump.
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
A 100-4 oil capacity Austin Healey 3
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
R Differential Oil Capacity Austin Healey 3
R # qts of oil, Capacity of radiator healey mk II BJ7 Austin Healey 8
H TR4/4A TR4 Oil Capacity Triumph 20
V Oil capacity of Datsun gearbox Spridgets 1
jvandyke oil capacity Spridgets 4
J TR2/3/3A TR3 Oil Capacity Triumph 7
healeyboz oil capacity Spridgets 1
P TR6 TR6 Oil Capacity? Triumph 7
davidk TR6 Transmission Oil Capacity on a non OD TR-6 Triumph 5
healeyboz Oil Capacity Spridgets 9
msoylemez datsun 210 trans oil capacity Spridgets 4
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
jerrybny Oil capacity after spin on adapter conversion Triumph 2
T GT6 Help on GT6 oil capacity Triumph 8
P Oil sump capacity Austin Healey 7
J Oil capacity MG 3
L BMC A-series: Oil in coolant British Motor Corp 4
A T-Series MGTD oil pump bypass valve MG 0
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
M Oil Pump for BN2 Austin Healey 4
tr6nitjulius Oil flow view inside operating engine Other Cars 4
R TR2/3/3A Oil Leaks Triumph 24
tahoe healey Gold Sparkle in Oil Austin Healey 15
B TR4/4A Oil Drain plug size Triumph 14
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
J TR4/4A Oil Deflector Triumph 4
A T-Series Mgtd oil pump alterations MG 2
S Add ZDDP to gearbox oil? Austin Healey 27
E MGB SU CARB OIL 1965 mgb MG 3
Kurtis No oil pressure Spridgets 5
E Oil leaking from the Tachometer cable Austin Healey 5
Walter74 Oil sump AH spares Austin Healey 5
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Basil Neat trick for reading oil level Restoration & Tools 7
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
nichola TR6 Oil pump drive barely engages Triumph 2
C TR2/3/3A Right oil Triumph 8
Lin Gearbox oil Austin Healey 1
E TR6 Transmission Oil Seal Triumph 13
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
B Oil cooler Austin Healey 21
S TR6 After I put in my new oil pump.... Triumph 3
B How regular should I change the gearbox oil? Austin Healey 5
Simmo TR2/3/3A Oil filter Triumph 5
S TR2/3/3A Dash Pot Oil Triumph 14
