oil brands?
Richard_Brown
Ok I read and read online and it seems that Castrol has a oil for older cars containing the right additives for solid lifter engines.
what oil are you using in your TR's?
I assume Synthetic oils are not a good way to go on older engines rebuilt or not.
TR4nut
Valvoline VR1 20W50 works for me.
M
Member 10617
I use Brad-Penn Grade 1 Racing 20w50 Semi-synthetic motor oil. It contains a little ZDDP.
Here's what an experienced British sports car owner/driver and mechanic told me: "In general, synthetic oil is a lot better than conventional oil (and more expensive). The term is a bit misleading: it is oil, made out of petroleum, just like the other, but it is made synthetically -- that is, it is concocted from pure ingredients, not just refined down to a certain viscosity. This gives much better control of its quality, and eliminates residual crud. I've always used synthetic oil in my old cars. Synthetic oil gets into places regular oil doesn't, especially when it is cold. It also finds leaks that the others don't."
DNK
Richard , a couple of stores carry the Brad Penn around here. I would go with that
TR3driver
Great Pumpkin - R.I.P
Funny thing is, all the other oil manufacturers that make that claim also give the amount of ZDDP present. Since at one time they claimed that reduced ZDDP was fine for all engines, Castrol's claims are basically meaningless (kind of like fresh frozen fish). Castrol also claims that any oil from a modern refinery can legitimately be called "synthetic", so that term is also meaningless (at least from them).
I've been running Valvoline full synthetic in all my old engines for many years. Unlike Castrol, I have never had a problem that I attributed to the Valvoline. It doesn't seem to leak any worse than conventional oil, and in once case actually reduced oil burning considerably from what it was after running Castrol GTX for a few changes. (Went from 1 qt/5000 on VR1, to 1 qt/500 with the GTX, to 1 qt/3500 with the SynPower. This was a Chevy V6 with some 150,000 miles on it before the switch to GTX.)
But the cost is kind of high, and my TR3 has started leaking pretty badly, so I'm going to pick up a case of VR1 and use that until I can get some of the leaks stopped.
JohnB
Bronze
When I finally get to 1000 miles on my new rebuild using Joe Gibbs Break-In Oil (2 oil changes), I'll be switching to Kendall GT-1 20w-50. My machine shop, having done lots and lots of racing engines, recommended them. Says the Kendall still has enough ZDDP in it to protect my Triumph engine.
FWIW the Kendall web site says:
"GT-1 High Performance with Liquid Titanium, SAE 20W-50, also contains a boosted level of zinc dialkyldithiophosphate (ZDDP) additive to provide additional wear protection and enhanced oxidation resistance for use in the most demanding applications. It is particularly recommended for use in turbocharged engines and in high-performance engines with flat-tappet camshafts, especially during the critical break-in period"
I know ads are always suspect and I can't seem to find out just how much ZDDP is actually in the 20w-50, but I do trust the shop owner who has dealt with this problem for some time, and has been a personal friend for years.
Just my 2 cents......
PeterK
I always used Kendall GT1 in my V8s when it was still Kendall green oil. But now the old Kendall is Brad Penn as the Kendall name was purchased by something else. If you want the original formula green colored oil, go with Brad Penn.
TR4nut
I just use the regular VR1. I change out my oil in this car much more frequently than my regular car that I don't see much benefit in the synthetic - also being a non-detergent oil I err towards more frequent changes.
TR3driver
Actually I was just looking at that the other day. The "street legal" VR1 has detergents and all the other additives to meet the API SL standard. And it also has the maximum recommended level of ZDDP.
Dudly
Brad Penn green here. Sort of like the idea of it being domestic and right next door from me.
Plus it works great in the spit.
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
L Oil Pumps Austin Healey 6
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
