Boggsy64
Yet another stumbling block! I had rebuilt almost everything drive train and suspension but the driveshaft. I was afraid to look at and hoped everything was ok (I thought removing it would be a "fun" job!). So I ventured to have a peak and lo and behold the universals were 90 degrees out, as I was afraid of! So while there decided to go ahead and tackle this job. Found all the nuts on both ends were rounded and beat up from previous work. Only had to cut 2 off with a grinder. Finally after 2 hours of vertical pushups got the thing off. Rear u-joint is bad, driveshaft appears slightly bent, nothing a little $ won't solve! I hope getting it back in is easier than getting it out! I don't think I can handle that much fun twice in one week!
