mikecyc72usa
So besides whacking my hand with a hammer Fri evening while getting the u-joint out of the yoke, I encountered the following:
U-joint from Spitbits. Always good. for whatever reason, one of the bearing caps can't go far enough in to let a circlip be put in. If I push it in, the u-joint seizes up. Got out the calipers, and the u-joint across the top of the bearing caps in the trouble direction is 70 thousands too long. Anyone else ever run into this?
The good news: the rebellious left side rear suspension that had taken it's state of independence too far is back in line. Of course, it sounds like the right u-joint is giving up, as I still have a rhythmic knock when I lift off the throttle. So Sunday I'm replacing that one. Hopefully without hitting my hand or the other hand with a hammer...
as above, it could be a errand pin in the cap.
