neilh
79 / 1500 midget -
Having finally got everything re installed the engine started fine. After a few minutes warm up the auto choke slowed it down fine, so I figured - lets see if it drives.
So, The clutch pedal goes down about 2/3 of the way before any significant resistance, then its firm and goes to the floor, followed by a major mashing of the gears as i try to shift!!!
The clutch & disc is all new, with original thrust bearing as it showed no signs of wear. I pulled the slave cylinder and checked the push rod - it has about 1/2 inch movement before it meets any resistance.
I feel the need to pull the engine again, but does anyone have any other ideas before i start!
TIA
neil
TIA
neil
