glemon
OK, sorry to keep this going but...if in fact your "rockers are tight" as others have mentioned the test for this would be to check the valves that are fully shut (valve side up, pushrod side down) and see if it moves freely, it should. In fact unless your engine (or at least your rockers and shaft)was recently rebuilt it would be very unlikely that your rockers are tight. If they were too tight the valves would not close and the engine would not run, if they are were a little tight they would loosen up on their own over time, so if the engine has been running for several thousand miles since the thing was monkeyed with I doubt if the rockers being tight is your problem.
If they are in fact too tight, and I doubt they are, this sounds like perhaps a misunderstanding or mistatement by your mechanic, but if they are too tight but loose enough for the motor to run, removal of the rocker assembly and some careful work with some fine sandpaper would probably be all that would be needed to get that slight bit of clearance needed to loosen it up.
I assume it was your valve lash that was too tight, as others have mentioned this is a routine maintanance job that should be checked/adjusted as stated in the owners manual, and it will make a difference in how much noise or clatter your car makes from the valve train, and can be very bad if you get too far out of adjustment.
Excuse me if everybody already knows this, but the rockers being tight would relate to their fit on the shaft that runs the length of the engine on top of the head, visable with the rocker cover off.
The valve lash and general pictures of the head and valve adjustment are illustrated and explained pretty well here.
https://www.macysgarage.com/myweb6/valve_adjustment.htm
