Hi Guys
Have any of you experienced an issue with the original Lockheed Clutch Master Cylinder in which fluid won't pump through the lines from the master?
I replaced the rubber plunger parts and there appears to be a good seal. I can get air to pump out of the fluid chamber but when I put in fluid and pump the clutch pedal there is no fluid pressure.
It should be simply obvious why this is happening but I can't for the life of me figure out what it is.
I'm not quite ready to shell out over $200 for a OE replacement, but I don't want to put in an aftermarket one if I can help it.
Any help you can provide to solve this problem would be appreciated. OR if anyone has a used OE master they want to sell, let me know and maybe we can make a deal.
Thanks
Kev
Thanks
Kev
