Hello All,
Well, I fixed my fuel gauge using the suggestion from this tech site
that Ford had a comparable float. (Mine was filled with gas.) I did
have to play with wire holding the float, Ford's was a little tight.
I got my volt gauge working, there were two hot leads on the back
and a ground dangling. I removed one of the hot leads and plugged in
the ground and it's working fine.
The next problem, in addition to the Rheostat, is that when I engage
the heater knob, it burns a fuse and I don't have any gauges.
The fuse is a AGC 20. I wonder if this is the correct fuse?
Any thoughts?
Thanks
Any thoughts?
Thanks
