Odd problem but it got me home!
steveg
Driving home from California Healey Week from Palm Springs area to Altadena, my car was running badly with backfiring and feeling like it took a lot of throttle to get anywhere. On removal of the piston, the needle dropped out into the carb:
attachment.php
Evidently the rear carb needle was sitting in place in the jet while the piston was going up and down. Made it home by keeping to the right lane with as little throttle as possible.
Amazingly the car made it home.
RAC68
Hi Steve,
Back in the winter of 1972, I drove from a town outside of Philadelphia to NE Pennsylvania, over to NYC, and back to the Philadelphia area. I had difficulty starting the Healey as we had a snow storm the night before but eventually got it going. As I remember, the car would have difficulty getting started from a stop and I needed to ride the clutch to get moving. However, once on the PA Turnpike, I had no difficulty cruising at 65 MPH or higher. Since I had not stopped for fuel along the way, once leaving NYC I filled the tank and was surprised to state I was getting around 60 MPG.
Returning to PA, I pulled the car into my neighborhood British car dealer to identify the reason for the difficulty I was having getting the car moving from a dead stop. Although during some occasions the car would start off normally, it turned out that the needle had loosened from the piston and vibration would shake and cause it to drop, blocking off fuel to that carburetor and the 3 cylinders it served. However, on occasion, the piston would drop catch the pin sufficiently to withdraw it and allow normal operation before vibrating loose and blocking fuel again.
Although the fix was easy once the issue was identified, there were times during the fuel embargo that 60 MPG looked good and I considered finding a way to drop the needle on command.
All the best,
Ray (64BJ8P1)
HealeyRick
All the best,
Ray (64BJ8P1)
Remember Cadillac tried that with the variable V8-6-4 motor in 1981?
Keoke
[h=2]Odd problem but it got me home![/h]
I suggest "U " do not use that mechanic any more----:highly_amused:
Bob_Spidell
I had this happen to me, but the needle didn't drop all the way out. Sometimes, it would stick in the piston and car would run fine; when it dropped, well, I had 3 cylinders.
The ends of the set screws that hold the needles in can get deformed with time/use/overtightening; I replaced mine.
steveg
steveg
It only dropped out when I pulled the piston out.
Keoke
The unusually high temperatures and humidity in California this year are prolly responsible for this problem.:highly_amused:
S Engine or Tachometer Odd Problem Austin Healey 7
R Odd problem Spridgets 3
philman Odd dash illumination problem Triumph 0
R odd starting problem Spridgets 1
kyreb1862 Odd Brake Problem On My 77 B MG 7
kyreb1862 An Odd Little Problem MG 7
Sarastro Yet another odd clutch problem. Spridgets 5
D TR2/3/3A Odd Distributor Problem - TR-3 Triumph 2
Cain TR6 Odd Problem - TR6 Boot Lid Triumph 1
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
K TR2/3/3A An odd brake question? Triumph 2
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
sparkydave Odd discovery, but still ran OK Spridgets 1
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
CJD TR2/3/3A Odd Commission number Triumph 16
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
D odd photo Jaguar 6
K TR2/3/3A An odd 56TR3 Commision Number? Triumph 8
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
R Odd Bonnet question Spridgets 2
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR4/4A Odd TR4 transmission question Triumph 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
T photo - odd request Triumph 5
frankenstang57 Sorta odd 1500 question... Spridgets 4
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
B Spitfire odd noise from Spitfire rear Triumph 5
