New loom. Designated wires go to each; the gearbox switch, centrifugal switch, OD switch, and throttle switch. Nothing on the switches or the wiring diagram indicates there is a correct side of each switch for wire orientation. In other words does it make any difference which wire goes to what terminal as long as it is to the correct switch? BTW, 100-4.
Hi Guest!
