charleyf
I have added the HVDA conversion to three cars. The first one was a TR3B which was already running a TR4A flywheel and clutch. The next two were TR4'swhich have the same flywheel as the late TR3/3A. On the last two I had a machine shop drill and tap the new holes and locating pins. Because I was building a whole car, the flywheel and engine were balanced together.
as Randall stated if you have the earlier bull nosed starter you will need a different starter. Because you will be using the Toyota bell housing there is NO cross shaft to run the Triumph throw out bearing. So you need to use the throw out bearing supplied by Herman.
Hope this helps your decision.
