Od/tranny 100-4
rossco
When I drain my overdrive and tranny is it necessary to remove both drain plugs? Or should the answer be obvious? I'm just changing the oil.
The O/D plug should have a mesh filter and a couple 'soft' round magnets. You want to clean the filter and magnets when you change the oil.
Thank you, DerekJ. Norman Nock says 30-w-50 in his tech manual. How critical is the combination? Anybody?
