OD question
Well, glad you guys caught that...now, I'm going back out in the garage to finish installing floorboards in a GT - the new & IMPROVED way using Fuzor 2-part glue instead of welding them in!
Welding works just as well...
/ubbthreads/images/graemlins/devilgrin.gif
Is welding broke?
/ubbthreads/images/graemlins/angel.gif
[ QUOTE ]
[ QUOTE ]
IFIN he is a "EE" he know what he is doing.---Keoke- /ubbthreads/images/graemlins/yesnod.gif
[/ QUOTE ]
Not the one's I work with. /ubbthreads/images/graemlins/frown.gif
[/ QUOTE ]
OH those fellas prolly Lucasites from across the pond.--Keoke- /ubbthreads/images/graemlins/laugh.gif
I'm not familar with the OD on MGs, but I looked at a wiring diagram, the OD activation switch and interlock switch are simply wired in series. Shouldn't be a problem if one of them fail. When it comes to an electrical switch that can fail and cause extensive damage to a very expensive part, it seems to me that this is something that definetly can be improved upon.
From what I've been reading, when this switch fails, it allows the OD to be activated at all times, in any gear. This means that it is failing in a CLOSED position. What should have been done was to have a switch designed so that when it fails, then the OD CAN NOT be activated. It should fail in the open position. First off, you won't destroy the trans, and secondly, you will know right away that something is wrong...not have to ask "How do I know if the stinking switch is fakackta??"
Whether a switch fails mechanically or electrically, it should fail so the circuit is NOT ACTIVATED. Unless I'm missing something here, this is a poorly designed switch.
Ahh, same guy that designed the timeing mark on the bottom.
The OD interlock switch is spring loaded to the off/contact open position. To my knowledge, they don't fail in the contact closed position. I guess there could be rare exceptions.
If you try to back up & the OD IS engaged, the transmission will simply lock up & stall the engine. A good warning not to try & force things. If you persist & force things, yes, something would break. Nothing can be completely idiot proof.
Well Matrix, Dave has already splained the switch's failure mode.However,based on the arguments presented here it seems if the switch has failed it is necessary that the engine and tranny be removed to replace a Ten Cent switch.Consequently, it would seem prudent to devise a work around rather than go through that extent at this time.At some future date when the clutch or other repair dictates the engine and tranny be removed then the ten cent switch can also be replaced.Further, adding a total OD Inhibit control when the tranny goes into reverse can be accomplished using a relay.---Fwiw---Keoke
Not sure why we have 5 pages devoted to this post, when it hasn't even been determined whether or not the darn switch is working. Check that out first.
It's called discussion. And the initial post was a question about the switch, which most the conversation has been about.
/ubbthreads/images/graemlins/grin.gif
Oh, when Jay and Tony get into it stand back. Lots of discussion insues and sometimes we learn something. Like what color the car should be, white walls vs black walls and other important things. LOL
[ QUOTE ]
[/ QUOTE ]
That blows my comment about broken/loose wires. I forgot that was causing the OD to not work - not the other way 'round.
FYI the switch doesn't work. I checked it both ways. So this winter, when we pull the engine, we'll fix that as well)
So, now its MOOT - gotta repair it...Janel - ask your mechanic who did Binabox if there's any way to reach the swirch from underneath.
I know you can take all the bolts out of the transmission, pull the shift tower & rotate the transmission 90-degrees either way - think you can even rotate it without removing the shift tower
But, I'm not recommending that, just a thought....&, without going outside to get under on of my cars, I can't remember if its possible to get to it from underneath.
Just remembered I've got a couple of OD's sitting in the garage...went & looked..if a guy gets the car high enough, he might be able to reach it from underneath....its on the side of the trans.
Janel,
If the switch is not working, then your overdrive is not engaging??
The stuff about not switching off the overdrive before shifting into reverse is plain and simple--BUNK!! Urban MG myth that continues.
Here's the real story--if the overdrive fail to disengage AND you shift into reverse AND you then force the car much harder than you ever did before (like trying to back-up over chocks) then you will do serious damage to the overdrive unit. The switch on the gearbox that y'all have been refereing to "connects" the electric current to make the overdrive engage. As soon as you shift out of 3rd or 4th, the overdrive disengages.
I back out of my garage all the time with the o/d switch flicked to "on"--always because I forgot to turn it off from the prior excursion.
If your gearbox switch has failed, you're in for one heck of a job. Yes, you could pull the engine but that's a bit extreme. I believe you can remove the shifter and the large panel on top of the gearbox for some access. There may be archives here but the UK BBS has much on this topic.
double post, sorry.
[ QUOTE ]
[/ QUOTE ]
My mechanic is my husband, remember?
He put the engine AND transmission in the car.
no, but i'm sure she can light a fire... /ubbthreads/images/graemlins/wink.gif
