wrenchpuller
Sorry Paul,
But damage to the overdrive caused by reversing, is not "Bunk". I only recommended to Janel that she checked before reversing "if the switch was stuck in the closed position". It does happen, have had experience of this twice in my career. Both were caused by double faults,
1: the solonoid drawing very high current.
2: the driver having the habit of shifting while the o/d was engaged.
First one was a Triumph 2000, solonoid was faulty, inhibitor switch contacts welded themselves closed, o/d rebuild under warrenty due to driver doing his upmost to reverse.
Second one, Healy 3000, solonoid was out of adjustment (early type Laycock o/d) solonoid pull in coil was not diss-connecting, same thing. Inhibitor switck contact welded together, o/d re-build at customers cost.
Both times the sprag clutch had been jammed so hard, it suffered damage.
Cheers Ric
Cheers Ric
