thomaslea1
The OD still seems to work when it darned well wants to. It will drop the RPM's when the switch is thrown but only engage every now and then. If I let it keep decelerating and flip the switch OUT it locks up in non-OD mode with no problem. Sometimes after it does decide to engage it'll drop out by itself, and it may or may not decide to let me re-engage it. I've done all the o-rings, new non-return valve kit, both new balls, seated the solenoid ball, oil pump feels tight and is in correctly, new screen (the old one was clean). Blasted it clean with 2 or 3 cans of carb cleaner and air pressure. Tried 30W non- detergent oil, RedLine MT-90, a 32 viscosity mineral oil, and currently 20W-50 oil.
Before I tear it out and look at the clutch material on the sliding member, I have concerns about the relief valve. I've attached a photo of the valve in exploded, semi-assembled and assembled state along with it's measurements.(Actually the picture can be seen at https://www.mgexperience.net/phorum/read.php?1,1483917 )The sleeve (with the holes in it) covering the valve itself does not show up in anyone's catalog!! The assembled valve seems to be about 0.052" from reaching the end of that sleeve.
I hope: someone has the measurement of the assembled valve OR the correct length of the spring, OR both. Would really make my day. All I'm coming up with is that it's possible the top end of the valve assembly is not sealing against the housing on the inside top. I'd spend the $90 to buy the new valve assy, but I still wouldn't be SURE that it was the correct length.
I have photo's of everything, just cant figure out to get one in the text.
Thank you very much,
Tom
currently sucking down a Miller Lite and swearing at the OD unit.
Tom
