AH 100-6 BN4
I am replacing the rear axle seal in my BN4. I am having trouble fitting the o-ring in the hub groove. The o-ring I received in the parts is a little too small for the groove - it stretches easily to fit, however will have to be glued in place for assembly - is this correct or should I source a better fitting o-ring. o-
Hi Guest!
