Wedge Now TR7's clutch is stuck!!!
sammyb
I finally bit the bullet, and purchased Tony Rhodes' great TR7 Stromberg carb mounts (man they're beautiful!!!) And for the first time in 8 months, my TR7 actually started and idled!!!
I went to put it in reverse and BUZZZZZZZZZZZ. No clutch.
The clutch is stuck disengaged!!!! /ubbthreads/images/graemlins/cryin.gif /ubbthreads/images/graemlins/cryin.gif /ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/cryin.gif
I finally had it towed down to my friends' shop. At least I was able to start it in gear and get it out on the street. I thought about driving it in gear with no clutch down to the shop (4 miles,) but the fear of something else happening caused me to just call AAA.
Serenity Now! Serenity Now!!!
Mark Beiser
Probably is the clutch slave cylinder. Easy enough to fix if that is what it turns out to be.
At least you have other toys to comfort you. /ubbthreads/images/graemlins/wink.gif
trrdster2000
Sammyb, if it turns out not to be a master or slave problem, it's just stuck to the flywheel. Put it in gear and start it up on a good long straight-away and just keep it in gear with the clutch engaged, after about fifty feet you will hear a big bang and that should solve the problem. Wayne
S
sammyb
Wayne,
That's what my friends thought, and that's what they suggested. I tried it, and got nothing, but I can't remember if my foot was on the clutch or not. I'm hoping that will solve the problem (no fee! /ubbthreads/images/graemlins/wink.gif ) Just as long as I don't have to pay to drop the tranny!!!
KLUTZ
Can you give us other Wedgies some information on the carb mounts you are speaking of, Sam?
Thanks
Paul
S
sammyb
Absolutely Paul!
https://mywebpages.comcast.net/rhodes/TR7_adapters.html
The guy who gets them made is Tony Rhodes, and he's a heck of a nice guy. A true TR enthusiast who came up with a better mousetrap...the guys at Moss and Vicky Brit have not given him the time of day, but I assure you that these things are a permanent and very elegant solution to the dreaded rubber mounts.
KLUTZ
Thanks Sam, they look like the real deal. I was hoping to get the 7 out of storage today, but the stupid snow changed those plans. Next weekend I hope...
I will keep the information and probably send an order in late spring, as I don't know the condition of mine until I get it back.
Paul
Kurtis
Sammy,
The clutch on my TR4 has stuck in the past after letting it sit for a while. I've always been unable to break it free simply by having my wife sit in the car with the clutch pedal depressed (and the car in gear) while I rock the car back and forth.
Geo Hahn
Worst case if it is really really stuck solid is to raise the back end with your floor jack, put it in a forward gear, start & rev the engine, double check you're in a forward gear, push in the clutch and have the wifey drop the jack. Be sure to have some open road in front of you.
Had to do this on the TR3A after it sat for a year. Sounds worse than it is and most importantly it worked.
Kurtis
[ QUOTE ]
[/ QUOTE ]
Hey Geo, if it works, you wouldn't actually need any open road ahead of you, would you? /ubbthreads/images/graemlins/devilgrin.gif
S
sammyb
It's fixed. My buddy got in the car and just romped on it around the parking lot, and then BOOM, it let go.
So I drove it for the first time since August or so, and it runs well, but the thermostat I put in isn't opening. Time to put the old one back in!
glemon Wedge TR7 Fan Clutch Triumph 5
johnrip Wedge tr7 clutch bell housing bolt? Triumph 4
T Wedge TR7 fan clutch worth anything? Triumph 1
johnrip Wedge tr7 5 speed clutch replacement Triumph 1
johnrip Wedge TR7 Clutch Throw out noise? Triumph 1
S Wedge TR7 Clutch Problems Triumph 2
S Wedge Clutch Problems - TR7 Triumph 4
M Wedge tr7 clutch linkage problems Triumph 0
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
