jlaird
I think it is time to get cracken and get Miss Agatha finished.
Today I received from Tony a few christmas items.
Spare tire tie down.
New mounts for my side curtins.
Tie downs for my top storage.
A jack set bag. I now have a jack, jack wrench, and a lug wrench.
All to be put under the Christmas tree I am told.
Time to start on the last, I hope, engine pull to replace the oil pump cover and the throw out bearing for a thicker one. Also have a few other bits such as the middle clamp for the heater duct hose and such.
Need to rebuild the oil pressure side of the guage, sticks a bit and work on the heater flaper pull cable.
Hope I have the energy to start on the engine pull in the morning. For some reason I am not looking forward to that. It will be the fourth time that lump has to come out, hopefully it is the last.
I pulled the trans out AGAIN, and took it back for a second time to the rebuild shop. They were about to just install another seal and hand it back to me when I insisted that they take a closer look into what was causing the recurring leak. Turned out that the input shaft had been burred slightly (during the rebuild) RIGHT AT the point where the seal contacted it. This burr was acting to slowly damage the seal, thus causing the recurring leak after approx 1 week of use. The rebuild shop installed a new input shaft & seal to resolve the issue.
