Now smoking & overheated...the car folks!
Afrodesia
So here is episode 2 of 'As the Key turns'...
Got fuel going to the carbs now & starts and runs like a champ...for about 3 minutes until smoke starts coming from the engine compartment & then it promptly overheats.
I have some advice to remove radiator and have it rodded but any other suggestions?
Thermostat? Water pump? Anything else? Any way to determine either of those? Could the smoke & overheat be related? I hope not...I'm afraid that it may be something more sinister *Insert ominous soundtrack*
TR3driver
Great Pumpkin - R.I.P
The "smoke" is probably steam, or oil burning off of some surface. I would focus on the overheating first. I'm assuming you mean that it boils over, not just the gauge reads high.
Thermostat is a definite possibility. For now, just remove it, or replace it with a modern (cheap) thermostat. We can argue later whether using the original (and very expensive) sleeved thermostat makes a difference. (Hint: I use a modern Tstat)
Water pump is less likely IMO, but still possible. I'd wait until you've tried the other things, then pull it out to inspect the vanes. They may have eroded away (but again, not likely).
I am assuming that the belt is present and tight, and that you've drained and refilled the cooling system. Is the fan present and accounted for? Can you feel the air coming off of it? How does the coolant look? Does the radiator get hot to the touch? Do you have the right pressure cap?
(The original TR3 radiator takes a special "long reach" cap. A modern cap will appear to fit, but won't seal or hold pressure.)
PS, Just for completeness, once it boils over you should turn it off and wait for it to cool before doing anything else. Taking the radiator cap off of an overheated engine is likely to get you a bath in superheated coolant, NOT a pleasant experience (and not especially good for the engine either). And adding cool water to an overheated engine may cause the cylinder head to crack.
TR3driver
One other, very minor thing: It would be good to mention what car you are working on every time you start a new topic; or else put it in your signature. Some of us suffer from varying stages of CRS and not all Triumphs are the same.
A
Afrodesia
Heading out to troubleshoot, thanks for advice.
Definitely smoke not steam...smells like burning oil.
hondo402000
it would also be a good idea to give us some history of the suituation
like car ran well a few days ago and now its doing this now(insert problem)
or car has been sitting for months and it started over heating
you get the idea
Hondo
70herald
Very hard to believe that a cold engine is overheating after 2 minutes. In such a short time, the smoke is probably oil which has dripped onto the exhaust. In two minutes that will be hot enough to create smoke.
What symptoms make you think it is overheating. Once again, be specific.
A
Afrodesia
Ok. I just bought the tr3 after it had been sitting for a while. It wouldn't start but yesterday I unclogged the fuel filter/linel line and now it starts great and sounds fantastic until it begins to smoke and overheat which takes about three minutes to happen.
As for the provenance of the car, I do not know much. I got it from a 19-year-old kid that got it when his dad died. So basically I'm starting from zero and will have to diagnose everything from a point of ignorance. Many gauges and indicators don't work either. Also, hard to roll so I think maybe brakes have seized.
Other than that, all's well!
A
Afrodesia
I opened the hood and saw coolant had sprayed out and smelled it too. Maybe a bit longer than 2 minutes but not by much. Plus it felt hot as hades in there. I'm sure smoke is dripping oil but I'm just hoping there isn't oil & water mixing and causing oil to get into cooling system and heat up.
70herald
Ok
I just saw your other thread, for the time being I would not worry to much about the smoke, in 3 minutes the engine isn't overheating enough to smoke...
Now before you do any damage, make sure the cooling system is as clean as possible. I would pull the top and bottom hoses to the radiator, and using your garden hose flush out the radiator and engine. You should get clean water flowing out. Also on the engine block there is a drain pull it out and there should be clean water flowing there also.
I would also open up the thermostat housing and make sure that it is basically clean there also. You can test the stat by dumping it in nearly boiling water it should open quickly, but I would just go get a standard modern replacement at your local parts store.
If not (and even if there is water flowing) take a wire hanger and poke around to get as much crud out as possible.
Then put everything back together, fill it with clean water, leave the radiator cap off and start it up. within a few minutes as the engine starts warming up the water should start flowing and you will see it in the radiator opening. You may need to race the engine to get enough flow to see water moving. This will also let any air burp out.
Then let us know if it is (still) overheating, or what symptoms there are.
70herald
Ok, Hot doesn't tell us allot yet... coolant spraying can be a result of loose/damaged hoses, overfilling the radiator...
To find out if you have oil/water mixing the take a look at the oil dipstick, if it looks like mayonnaise we have a problem, also look in the oil fill hole. If it is clean there probably isn't water getting into the oil.
Start by flushing out the cooling system, and then onto the next steps
A
Afrodesia
Once again, much obliged for the help.
Seems that previous owner overfilled the cooling system (with straight coolant I think) and that's what sprayed out. Easy one.
Still smoking so it's running to see if maybe oil overpour is what's doing it but isn't getting any less after about 15 min of engine running. Looks like its coming from manifold Area. I was hoping it'd be an easy valve cover gasket replace but...
Can the manifold be removed relatively easily and gasket scraped & replaced?
Boy, dad could do this blindfolded.
Should I start a new thread?
TR3driver
I agree with all but that. On a stock TR3A, the radiator fill is on an extension that sticks out about a foot behind the upper radiator tank. You might be able to see a bit of swirl when the Tstat opens, but the water doesn't circulate through there.
Any trace of oil in the water will quickly find its way to the top (at the cap) and be very obvious. I seriously doubt that is the problem anyway.
One thing that might not be obvious, the radiator is not supposed to be full to the top when it is cold. It is normal for there to be a couple of inches of air under the cap. If you try to fill to the top, the excess will be forced out of the overflow tube when the engine warms up to operating temperature. Speaking of which, I recommend installing an overflow tube if you don't already have one. Route it forward along the inner fender and let it hang out to near the ground.
70herald
There is no oil running through the manifold gasket so no reason to think that it is coming from there. It only takes a TINY bit of oil to create a HUGE amount of smoke. Clean up any spilled oil and ignore if for the time being.
By the way, even if the valve cover gasket looks good, the cover itself was probably over tightened at some point in its past and is slightly bent which will let it leak unless you straighten it out perfectly. I replaced the cover on my engine with a nice new alloy cover, and a silicon gasket. no more leak, no more burned oil smell.
TR3driver
That's a problem as well, straight antifreeze doesn't cool nearly as well as the recommended 50/50 mix (which still isn't as good as straight water).
Removing the manifolds is a bit of a chore; and since there isn't any oil in that joint, probably not what you want to do. Time for a little detective work, find where the oil is coming from. Most common would be the rocker cover, but I assume you've already checked that.
Other possibilities in that general area include the head gasket and bolts from the generator bracket into the engine block.
Geo Hahn
Afrodesia said:
Ok. I just bought the tr3 after it had been sitting for a while... I got it from a 19-year-old kid that got it when his dad died. So basically I'm starting from zero and will have to diagnose everything from a point of ignorance...
Well <span style="font-style: italic">ma'am</span>, you got it running which is a major moment and a morale boost that can keep you inspired for what's next.
Sounds like you may be anxious to get this on the road but I, for one, would take some time to go through the basics including replacing all fluids, sorting out the brakes, replacing the fuel lines and preceding all this with a thorough power-wash if there is any build-up of old grease or oil.
I probably wouldn't jump into rodding the radiator or pulling the header until I had some solid evidence that was needed.
Also check the date code on the tires before you're tempted to drive.
A
Afrodesia
Didn't realize my anxiousness was so obvious. Yes I did.
Just FYI, you mean "well ma'am." ; )
mrv8q
Geo Hahn said:
Afrodesia said:
Just FYI, you mean "well ma'am."...
My mistake -- lady alligator wrestlers are sufficently uncommon in this part of the country that I leapt to an incorrect conclusion.
Geo: Too smooth!
Afrodesia: Too cool!
P TR2/3/3A ignition switch smoking Triumph 12
I Bugeye smoking Spridgets 9
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
P Horns smoking: rewire? Triumph 3
D MGB 66 MGB smoking MG 26
TulsaFred Bugeye smoking from the breather tube Spridgets 12
T TR6 My TR6 is smoking aka burnout or powerskid Triumph 0
Basil Is someone smoking dope? MG 16
T Help my car is smoking Triumph 7
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
Kurtis 1275 Smoking Problem... Spridgets 7
veale001 TR6 TR6 Smoking? Triumph 33
Hooper11772 OMG stop smoking already!!!! Spridgets 75
Stewart Smoking B MG 2
roofman Looking for a smoking deal! Triumph 2
MTribe 1st start after rebuild, smoking exhaust manifold? Triumph 7
D MGB Smoking MGB MG 17
Twosheds TR2/3/3A Smoking TR3 Triumph 26
hondo402000 alternator up grade and smoking dash Triumph 19
mgb4tim New server smoking! MG 14
D Smoking Generator Spridgets 20
T Bugeye smoking problem - needs a patch Spridgets 13
S TR2/3/3A TR3 Smoking Rich? Triumph 6
P I Started Smoking MG 6
jaybird Somebody's smoking crack MG 11
B What's this cat smoking???? Austin Healey 24
B Just Installed Rebuilt Generator - It's SMOKING?! Austin Healey 8
T smoking engine Jaguar 8
G Smoking like a chimney - but only sometimes Triumph 9
J Continued from... "Is Smoking Bad?" Lotus 4
J Smoking is that Bad? Yeh Sure, Help.. Other British Cars 12
H Still smoking! Triumph 4
J Smoking BN2 Austin Healey 14
bighly Smoking exhaust after warm-up Austin Healey 13
T overheated ignition coil ? Triumph 21
D So...uh...it overheated... Spridgets 15
Rick_Thompson TR2/3/3A Sanford Fl All British Car Show, April 6th Triumph 0
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
A Why is my car making this noise? Other Cars 5
N Wanted Help with car identification Other British Classifieds 2
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
tr6nitjulius General TR British Car Mechanic SoCal Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
Hamish Racing TR2/3/3A Road trip video - car info Triumph 0
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
