fmichaels
why i am putting the car together before i get the tub painted. seems i was bored and started setting up the new tierods to the steering arms. noticed that the steering arm has a tapered hole. the tierod also has a taper. problem is, the new tierod does not fully insert into the steering arm hole. only the threads insert, the tierod taper is larger than the steering arm hole. got out the old a-frame steering arm and the hole is larger than my new arm. what's going on? i have no manuals that talk about this. should this be a simple interference fit or is there machining involved?
