I bought a new steering rack from Victoria British and can't get it to align so that the wheels are parallel. After a puzzled morning i thought to compare it with the old rack. I can't get enough adjustment at the left hand tie rod. When I turn the steering as far as it will go to the left the shortest distance that I can make from the center of the spline on the end of the steering column to the center of the bolt that goes into the steering arm is 15 1/2". The comparable distance, also turned all the way to the left, on the old rack is 14 1/4". The car is a 1958 Bugeye. The alignment of the steering rack, according to the manual, is fairly simple. I checked that I ordered the correct rack from VB, they sell two. It is possible that they sent me the wrong rack, more likely that I have done something dumb. Any help would be appreciated.
