Ted_Merendino
Hey guys. I finally got around to taking a look at the car. Penny has a 1098 motor and I'm using the later electric solenoid, which was pictured earlier. I used a continuity tester to test the solenoid. When the igntition is turned to on, the points make contact and there's a current across the solenoid. It turns out this was the component that was making the 'click' noise. I then tried to test for voltage after the solenoid and before the starter. I didn't get voltage in either spots but I think my meter might be out of batteries... I'm going to put some new batteries in and give it another go.
