mjobrien
A question from a novice at points based distributors. Does the rotor actually touch the leads inside the distributor cap or is there a gap where an expected spark jumps across ?
In setting the initial timing for cylinder one, I wanted to use the fact that the coil lead and the number one cylinder lead on the cap, would connect and give me a good approx of where to tighten the distributor down to start with?
Thanks,
Michael.
Thanks,
Michael.
Hi Guest!
